CR 27 Weigh-In Results!
Postby Keithlewis » Fri Jul 11, 2008 1:35 pm
CAGE RAGE 27 Weigh-In Results!
Phil Baroni (77kg/169.7lbs) vs. Scott Janson (77kg/169.7lbs)
Heavyweight British Title:
Mustapha Al Turk (111kg/244.6lbs) vs. James McSweeney (101kg/222.6lbs)
Light Weight British Title:
Jason Young (70.2kg/154.7lbs) vs. Francis Heagney (70.3kg/154.9lbs)
Feather Weight British Title:
Ashleigh Grimshaw (65.8kg/145lbs) vs. Robbie Olivier (65.8kg/145lbs)
Robert Berry (110kg/242.4lbs) vs. Neil Grove (126kg/277.7lbs)
Christian Binda (63kg/138.9lbs) vs. Brad Pickett (65.8kg/145lbs)
Mark Brown (76.7kg/169lbs) vs. Wesley Johnson (73.4kg/161.8lbs)
Aisling Daly (56.9kg/125.4lbs) vs. Eva Liskova (55.5kg/122.3lbs)
Stav Economou (125.7kg/277lbs) vs. Piotr Kusmierz (112.5kg/248lbs)
James Elson (83.2kg/183.4lbs) vs. Dave van Gasse (84kg/185.1lbs)
Tom Watson (83.8kg/184.7lbs) vs. John Philips (83.8kg/184.7lbs)
Mavlyanov (70.2kg/154.7lbs) vs. Jody Cottham (70.2kg/154.7lbs)
