10 Quick Fixes to Save Your Running Knees Long Term
Grappling, Wrestling, Techniques, nutrition, sponsors, tryouts and more.
Postby NWOWolfpack » Thu Feb 19, 2009 10:40 pm
Ten Quick Fixes to Save Your Running Knees Long Term
By Matt Russ
for Inside Triathlon magazine
Unlike swimming and biking running is weight bearing and involves compressive forces many times body weight. The eccentric (lengthening) muscle contractions are also very hard on your body. If you are a large or heavy set person; harder still. If you plan on running long term there are some basic rules to follow which will keep you striding long term.
1. Take at least 1-2 rest or active recovery days per week. This means no impact giving your joints a rest from the pounding forces that running produces. Less experienced runners may need 2-3 rest/recovery days per week.
2. Perform no more than 1-2 "break through" or high intensity interval work outs per week. Speed work puts more stress and the body, and requires more recovery time. This type of training must performed prescriptively and carefully. Try to schedule these key work outs directly proceeding a rest or recovery day.
3. Train in 2-3 day cycles, with a rest or recovery work out in between cycles giving your body to some space to recover from and adapt to the training load. Some athletes will need more rest and less training, especially as intensity increases.
4. Change your shoes out frequently. A good rule of thumb is at least 3x per year for a high volume runner. You may want to write the date you purchased your shoes in permanent ink on your shoes for reference. Buying shoes is expensive, but so is your insurance deductible.
5. Take the supplements Chrondroitin Sulfate and Glucosamine. I don't recommend a lot of supplements, but this combination has shown promise in clinical studies, and in control groups of people suffering from knee pain. One works as an anti-inflammatory; the other helps regenerate cartilage. I know of several orthopedic surgeons who are recommending the supplement to their patients and it may be worth a try.
6. Increase your volume of endurance training by less than 10% per week. Bringing your mileage up too quickly is a sure fire way to promote injury. Your body sustains stress (training) and is initially weaker from it, then compensates and adapts to get stronger. If you put too much stress on your body, it can't compensate and continues to break down.
7. Listen to your body. In my experience your body gives you an indication that you are about to sustain an overuse injury. This may be in the form of a slight or nagging pain. If you stop training at that point, you will more than likely be all right after a few days rest. If you try to push through the pain you may end up with a more serious injury that can take weeks or months to heal.
8. Periodize your training. Periodization simply means administering the right training at the right time. You prioritize your training into specific cycles that move towards a goal (race). Your training moves from the general to the specific and from low intensity to higher intensity as you approach your peak. The implication is that you are performing your most race like training just prior to your goal race. This means less stress on the body throughout the year because you are not performing high intensity training all season long. An experience running coach can help you set up an annual training plan delineating your training cycles.
9. Perform strength and flexibility exercises to keep your knees strong. One of the more common overuse injuries is "runner's knee." This inflamation is caused by the patella not tracking properly, much like a tire that is out of alignment. By keeping your quadriceps flexible and strong, particularly your vastus medialis, you can help prevent this condition. If you are an endurance runner you do not need to overwork these muscles or use a lot of weight, but light strength work performed correctly can help prevent injury.
10. Cross train. One of the benefits that multi-sport athletes have over runners is that they are able to perform swim and cycling work outs in between run work outs. This helps reduce the stress caused by the pounding of running, but the athlete still receives the aerobic benefit of training. A good time to cross train is when you have a less specific recovery work out scheduled or a lower intensity base work out. If you use a heart rate monitor you can stay in the same heart rate zone as your prescribed run work out. Swimming, cycling, stepper, elliptical trainer, or even hiking are all good examples of cross training work outs.
An eleventh I would add is to run properly. Unfortunately this is not a quick fix. If you are over-striding or running with a very low stride count your impact forces increase. By addressing your form you will put less stress on your body. Video analysis is a great way to identify and work on your form limiters.
Matt Russ has coached and trained elite athletes from around the country and internationally for over ten years. He currently holds expert licenses from USATriathlon, USA Cycling (Elite), and is a licensed USA Track and Field Coach. Matt is head coach and owner of The Sport Factory, and works with athletes of all levels full time. He is a free lance author and his articles are regularly featured in a variety of magazines such as Inside Triathlon, and Triathlete. Visit http://www.thesportfactory.com for more information or email him at coachmatt@thesportfactory.com
Return to “Training, Tryouts, Competitions & More”
