Mass Effect 2 on Two DVDs
Coming Attractions, Game Analysis, Reviews & Screenshots
GamePro 55
Gang Unit
Gang Unit
Postby GamePro 55 » Fri Dec 04, 2009 2:58 pm
The Mass Effect Community Forums have word that Mass Effect 2 will span two DVDs for both Windows and Xbox 360, and the Xbox 360 version will require a one-time disc swap (thanks Kotaku). Word is:
Ok some details for you.
1 - Yes, there are 2 game discs for both the PC and Xbox 360 versions, both the Collector's and standard editions.
2 - There is a 3rd disc with the Collector's Edition. This is a movie DvD containing making of and other bonus information.
3 - The PC version is a standard install. You install the information from both discs and then play with 1 disc in the drive. No swapping.
4 - The Xbox 360 does not have an install and does require disc swapping during play.
5 - Even though there is a disc swap, it occurs at a carefully planned place in the game (that does not interfere with gameplay) and is done once. You do not swap back and forth. 1 swap and then done.
6 - Why 2 discs? Answer: Because you cannot fit this much awesome on one disc.
All Noobs must hang!!
Return to “Video Game Previews, Analysis & Reviews”
Users browsing this forum: No registered users and 0 guests
