Get into locked villages and gates:
To get into locked villages or gates, one must utilize their jumping skills. You jump by pressing the Y button. These tricks will allow you to get into locked villages and gates as such:
Gorelin Village - To the left and right of the locked gate there should be some carts near the wooden fence of the vilage. Jump on one of these carts, then jump on top of the wooden fence to jump over and into the village. To get back out, look to the (inside) right of the gate. There will a cart leaning against the fence there. Jump on the cart, then on the carts handles to jump back out of the village.
Karga Clan Camp - To the right of the locked gate there is a big rock, jump on it. Then jump from the rock on top of the wooden fence (you may have to jump again on the fence to get higher on the fence). Then walk on the fence and jump down to the other side. To get back out go to the (inside) right of the fence behind the stone pillar. Position your character between the wooden fence and the stone pillar. Keep pressing Y (jump button) until you get on top of the fence then jump over to the other side.
Karga Clan Treasury - Warning - you need a teleport stone for this trick or you will be stuck and have to quit! - Follow the mountain path in the Karga Clan Camp to where Ulta Karga's house is. Adjacent to his house is two other houses that are seperated by a giant rock. Jump on and then behind this rock. Then go behind the house on the right. Look your left up the mountain side. There should be a crevace you can jump in. Keep jumping up in the crevace until you reach the top of the cave of the Karga Treasury. Go over to the edge of the cave until you see the red "locked gate" icon then slide down that side of the cave until you fall. If done correctly you should land inside the treasury and able to get the relic frame. To get out use the teleport stone near the gate and teleport to the Karga Clan Camp entrance. Then go back to the treasury and retrieve the teleport stone behind the gate.
Other cheats but WARNING as you will any achievements you have gotten:
Hold down LB + RB and press A. After the text box appears, press X to open the keyboard and enter. All of the codes aside from the bonuscodes will disable achievements and require you to enter "twoworldscheats 1" first. Warning! By entering that code achievements will be permanently disabled!!
Ec.dbg addskillpoints - Add skill points
AddGold X - Adds Gold where XXXX is the amount of gold added
AddParamPoints X - Adds Param Points, where X is the number of points added
AddSkillPoints X - Adds Skill Points, Where X is the number of skill points added
AddExperiencePoints XXX - Adds XXX amounts of experience
Bonuscode 9728-1349-2105-2168 - Armor of Darkness
BonusCode 9470-4690-1542-1152 - Aziraal's Sword of Fire
Create Lockpick - Creates a lockpick
Bonuscode 9470-6557-8820-9563 - Great Shield of Yatolen
Ec.dbg levelup - Level Up
Ec.dbg skills - Makes all skills available
Create Teleport_Activator - Recover lost teleport activator
ResetFog - Reveal Map
Bonuscode 9470-6557-8820-9563 - Spear of Destiny
Bonuscode 9447-1204-8639-0832 - The Great Bow of Heaven's Fury
Jump2 - Transports player to where mouse is pointing
PhysX.Door.RemoveAll 1 - Walk through doors and walls
Enjoy......
Two Worlds: Cheats
- keithlewis
Return to “Hints, Cheats, Walkthroughs & Guides”
Users browsing this forum: No registered users and 17 guests
